ROBERT'S WEB SITE
RV7
DWG-13A
LW aileron
LW aileron: Marked an drilled #30 bit the counter balance using the V-Block and bench drill. Removed then CS all the holes for the dimpled skins ribs etc. the primed the CB pipe, Drilled holes on A-704-L&R. Bent aileron skin in bender as per plans.
RV7 Home
5634
After Inspection
AIR FILTER BOX
auto pilot
Brakes
Cowling
Engine Baffles
Engine exhaust
extra parts
Firewall forward kit
Firwall forward kit
1663
Lights/strobes
Panel
PITOT/STATIC SYSTEM
SPINNER
Tanks
89
369
988
Wiring & connectors
RV-7 Home
