Finished bending forward skins of rudder, then measured the distance of center hole of MD3614 and MD 3616M rod bearings to the main spar on front of rudder per DWG 7. Set to: Top bearing to 51/64" Middle bearing to 59/64" Bottom bearing to 1 and 1/16" Installed washers and nuts on bearings and tourqed Finished rudder riveting etc. but need to do the fiber glass etc.
