Brief Description: Drilling RW for conduit install
Drilled RW for 3/4" and 5/8" holes per vans. started installing conduit after deburring holes. The engineer who designed this apparently hadn't tried it. Got it thru a few ribs the I deceided it would work better starting from the tip to the wing root but when I got to the ribs that were close together it was a slow process. will try finishing this wing tomorrow.
