STARTED WORK ON SEALING DOWN THE WIND SCREEN PER MANUAL. FABRICATED AND INSTALLED 6 BRACKETS AND RIVETED AROUND THE FRONT AND SIDES OF THE WIND SCREEN TO F-7106. TAPED THE WIND SCREEN AND ROLL BAR AFTER MEASURING OUT THE AREA THAT GETS THE FIBERGLASS. USED POLY PIPE 2" X 20 MILL PIPE WRAP FOR THIS AS THE RESIN SHOULD NOT STICK TO IT. SANDED DOWN THE AREAS FOR THIS AND CLOSED AND LOCKED THE SLIDING CANOPY AS SOME OF THE FIBERGLASS WILL HAVE TO OVER HANG THE REAR SLIDER CANOPY. STARTED LAYING OUT THE 2" ROLL OF GLASS TAPE AND MIXED THE RESIN AND HARDNER AND SQUEGGED THE RESIN/WITH HARDNER INTO THE TAPE AFTER WETTING THE AREAS FOR THE TAPE.
