Cut fuel line's shorter where they will connect to the wings, per info on Van's airforce site(31/4") from side of fuselage. Decided to cut the wing tips, used an air die grinder w/plastic cutting disk.Tip not going far enough forward, talked to van's and said I may want to use a long clamp to force it closer. It seems to be about 1/8 aft of the aileron.
