DECIDED TO CUT OUT THE EYELETS ( 2 ON WING FLAP HINGE AND ONE ON FLAP HINGE AND THEN CUT THE HINGE PINS TO MAKE FLAPS EASIER TO REMOVE AS PER WRITE UP FROM VAN'S FOUND OUT IT WAS MORE DIFICULT TO PUT THE SHORTER PINS IN THAN THE LONGER ONES. SOMETHING MUST BE WRONG
