11/26, 27, 28 INSTALLED HEX FLAP RODS AFTER REMOVING THE OLD ONES, STARTED INSTALLING THE WING ROOT FAIRINGS ( 14 K1000-08 NUT PLATES AND AN 426 AD3-4.5 RIVETS AND ALSO THE K1100-08 cs NUT PLATES TO THE BOTTOM OF THE WING ROOT, DRILLED AND DIMPLED THE FAIRING AND HAD A MAJOR PROBLEM PULLING THE FAIRING AROUND THE WING LEADING EDGE'S SO IT WOULD FIT IN THE PROPER HOLES. I'LL HAVE TO REMOVE THESE WHEN I INSTALL THE WINGS TO THE FUSELAGE AND CUT THEM FOR THE SEAL'S TO FIT.
