7/4,5,6,7 MORE WIRE WORK IN FUSELAGE, REPLACED LEFT FUEL LINE TO LEFT WING, IT HAD A KINK IN THE TUBING THAT I NEEDED TO REPLACE. NOTE TO SELF(DO NOT ATTEMPT THIS AGAIN USE FLEX LINE INSTEAD) MORE WORK ON INSTALLING PANELS FOR FIRST RUN UP. DECIDED TO GO WITH EAA INSURANCE SO WILL HAVE TO START THAT A FEW DAYS BEFORE RUNUP AND THEN DO THE WEIGHT AND BALANCE ON THE AIRCRAFT
