FINISHED WIRING RIGHT WING AND TESTED LANDING,TAXI, NAV AND STROBE LIGHTS. RIGHT STROBE NOT WORKING, FOUND LOOSE PIN IN MOLEX CONNECTOR IN BACK OF COPILOTSEAT AND REPAIRED ALL TESTED OK. TESTED HEATED PITOT TUBE AND THIS NOT WORKING HAD 12V TO IT AND WIRES ALL HOOKED UP CORRECTLY. I SUSPECT THE HEATER PCB IS BAD WILL TALK TO GRETZ ABOUT THIS
