8/20, 8/2 1Measured the mounting of the HS. Measured 11.8 degrees with 11.8 degree on the fuselage to give me the 0 degree incidence Had to purchase 3/16" rod to fit in the tooling holes for this measurement. Drilled and deburred the holes for mounting the HS and installed the bolts
