ROBERT'S WEB SITE
Date:  11-17-2006
Number of Hours:  5.00
Brief Description:  pitot installation
Riveted pitot heat mount bracket along with a fabricated support for the sensor that I installed nut plates to for easier removal. Marked and cut the opening in the wing skin for the mount to go through. Ran 2 #14 wires for power/ground to the pcb as well as the cable for the panel led's. This gretz heated pitot will sense the temperature at the probe so the leds will tell me when to turn on pitot heat and when its not needed All these were run thru the wing conduit. I had to cut an opening in the conduit at the location of the pitot tube.
sensor pcb installation
left bottom skin cut for pitot
pitot in left wing
pitot in left wing
