ROBERT'S WEB SITE
RV-7
OPT 10,12
bus bar fabrication
cut and drilled brass bus bars from 1/2" stock, one long one for the switch breakers and a short one for the circuit breakers. I then cut ,drilled , deburred and installed the side hinges for the lower cowl
bus bar in
lower right cowl hinge
lower left cowl hinge
RV7 Home
RV-7 Home
5503
After Inspection
AIR FILTER BOX
auto pilot
282
Cowling
25
234
490
Engine Baffles
extra parts
Fiber glass kits
Finishing Kit
Firewall forward kit
First Flight
Firwall forward kit
Flying
1663
Heated pitot
Inspection Prep
Instruments
Lights/strobes
MAIN GEAR
Panel
62
358
Parking Brake
Phase1 Flight testin
PITOT/STATIC SYSTEM
Primer
Sale of N64RL
SOUND PROOFING MATER
SPINNER
988
Wiring & connectors
