ROBERT'S WEB SITE
RV-7
OP30
battery ground connection
Drilled 1/4 " hole per instructons for bat ground strap and installed nut plate for the bolt. Drilled 1/2 " hole for wire run to master and starter relays
plate nut for battery ground
RV7 Home
RV-7 Home
5503
After Inspection
AIR FILTER BOX
auto pilot
282
Cowling
25
234
490
Engine Baffles
extra parts
Fiber glass kits
Finishing Kit
Firewall forward kit
First Flight
Firwall forward kit
Flying
1663
Heated pitot
Inspection Prep
Instruments
Lights/strobes
MAIN GEAR
Panel
62
358
Parking Brake
Phase1 Flight testin
PITOT/STATIC SYSTEM
Primer
Sale of N64RL
SOUND PROOFING MATER
SPINNER
988
Wiring & connectors
