ROBERT'S WEB SITE
Date:  9-28-2006
Number of Hours:  5.00
Manual Reference:  Dwg-46A
Brief Description:  Engine mounting
Installed mounts per drawing. top Large(soft)VP 50900-71 engine to mount cup and VP 50074 (hard) from mount cup aft using AN7-43 bolt's and large washer J-22181 at bolt head's
On bottom 2 mounts I reversed the rubber mounts(smaller or harder on engine side and larger(softer ones aft of mount cup an and installed extra large washers on the forward mounts to fill the indentation of the engine also used the longer bolts AN7-44 on the two bottom mounts. tourqued these 4 bolts till they bottomed out on the brass spacers installed between the rubber mounts the lined up the holes for the cotter keys. Started work on exhaust sys
engine on
engine on
engine on
engine on
