Decided to tackle the wing tip light lens. I started by cutting the lense in two pieces, and this was the easy part, trying to fit it in a opening with all kinds of angles and shapes isn't easy. After cutting with a die grinder I reverted back to a metal shear which seemed to work well along with a few files etc. Mounted two nut plates for 2 #6-32 screws one on top and one on the bottom and finally got one mounted for the right wing
