Primed brackets for wheel pants and assemblied.Finished same. Tried to install gear legs to motor mount. Too tight to put on. Called van's, Bruce said they were fit at factory so should fit but are suppose to be tight, said it was probably the powder coating that I would have to be sanded down. Also rather than breaking my back lifting the fuselage while Linda tried to put the gear legs in I would shop for a shop crane
