BOB'S WEB SITE
Date: 3-31-2008
Number of Hours: 6.00
Brief Description: Re-do Rudder Parts
I e-mailed Debo Cox about my bend issues on .040 and he responded with, I believe good advise. I also cut a 100mm strip of .040, as he does, and tried it that way. I then took it to the table saw and ripped it to the required width and I truly did have a very straight angle at the required bend degree and meeting the flange specified width. The experience of the guys before ya really pays off...all one needs to do is - listen to them - and do it the way they tell ya.
Fitted the skeleton of the rudder together, drilled, clecoed, measured, disassembled, deburred, and primed with zinc-chromate (modified).
Re-assembled the parts and riveted them together.
Skeleton riveted, primed
Skeleton standing primed, riveted
Top rib ready to prime and add
