Reinstalled starter. Tested oil temp gauge in hot water, it's dead. Ordered new from A/S. Ran up for oil leak check and to get a voltage reading. 12.4 at 1500 RPM and higher, with very low charge rate.
Experimented with some weather stripping to close gap in forward part of pilot-side door.
Prepared to adjust trim stops but Sam not available for the "crawl". Added that to post flight tasks.
