Brief Description: Prepared for windshield reinstall.
Jeanne and I spent most of the day cleaning the black goop and the silicone from the two windshield strips, the windshield itself, and the airplane.
Tried unsuccessfully to position and secure the jury struts.
Pulled the aileron cables through and connected them to the aileron bellcrank (loosely).
Tightened all wing attach bolts and the 16 AN3 bolts that compress the center spar section. Two of those were too short and one stripped when tightened. Spent about an hour cutting it off with the Dremel. Replaced with longer bolts.
Pulled scat tubing and wires out of the wing roots.
