My Airplane Projects
Date:  5-20-2020
Number of Hours:  0.00
Brief Description:  FWF wiring +...
Sam adjusted trim tab travel to specs. I installed data plate and mag compass on dash. I tested primer with 100LL and it seems to work without leaking. I selected the larger start button and installed it in the panel. Located correct nut and secured oil pressure gauge to floating panel.
I routed, connected, and secured remaining FWF wiring. In attempting to install filter capacitor I loosened one of the long generator bolts and was not able to rethread it. Generator will have to come back out to install filter, hook up magneto P leads, Also, we are missing one of the special nuts for the connecting posts.
Start button - at last!
Data plate and compass.
Wiring
Wiring
