Went to airport and picked up all tools and tidied up bench. Located correct screws and replaced voltage regulator cover. Installed correct end on battery ground cable. Cleaned battery box connection points to improve ground connections. Installed solunoid with new correct hardware. re-bent right-hand windsheild strip to give bigger opening. Pulled all control cables inside fuselage to protect them while painting. Thoroughly vacuumed fuselage. Swept entire work area. Selected stock (.063) and Kurt cut new floatinng panel blank for me (on his own time.) Hand filed edges. Played around with instrument placement.
