Shortened and installed ends on previously installed RG-400 COM antenna coax. Installed phono plug end on VOR antenna wire. Noted much corrosion around antenna mounting that needs to be addressed. Soldered ends on both antenna wires going into NAV/COM tray. Cleaned up COM antenna ground lug and replaced mounting hardware. Did a major workbench cleanup and began to look at instrument panel floating section layout.
