Brief Description: Finished glovebox and CB panel.
Finished glovebox mods and mounted on panel with four screws and tinnermans. Finished CB panel and mounted with bolts. Pulled breakers and switches from inventory and identified needed reorders. Found bus bar stock. Cut shielded wire for headsets and picked up grounding ends and other spplies for home headset wiring construction.
