Brief Description: Worked on electrical system design.
Sturied the possibility of extending the old fuse "shelf" forward to allow installation of breakers. Designed and fabricated extension out of .032 alclad. Reviewed panel layout with Jeanne and discissed options. Jeanne helped me remove the old map light from under the panel. Reviewed proposed panel layout and CB mounting with Bill. Bill suggests just extending CB panel downward so that breakers face outward instead of downward. Also suggested that there is an option to add small sub-panels under panel for headset jacks and 12V outlets, as has been done in 195's.
As to circuit design and switches, Bill suggested deleting separate landing light lamp breaker/switch in favor of just one breaker and up/down switch due to the internal design of the Grimes unit.
Discussed headset jack wiring with Chris Wilcox.
Added two missing Cherry rivets, right rear seat pan and bottom left doorpost.
