Brief Description: Replaced battery cable and brake lines.
In the morning I removed the first battery cable I had put in, as it will not be long enough when the cable is routed according to plans. Prepared and installed new longer cable, including making one new hole in forward gearbox bulkhead as specified in the plans, In the afternoon after Sam arrived we installed the four CherryMax rivets at the front of the floor boards. We fabricated a second flexible brake line, and installed L&R brake lines as far back as the gearbox area.
