My Airplane Projects
Date:  12-1-2020
Number of Hours:  0.00
Brief Description:  Weatherstripping, heater control.
Warm day for Dec1. 50 outside, nearly 60 inside with heather running. Removed weatherstripping from doorframe and installed new ½ X ¼ inch open cell foam on doors. Same on window frames.
Noticed heater control misadjusted, not getting full heat. Removed and lubed cable and adjusted cable connections to obtain full travel.
Noted oil leaking again from somewhere high on aft end of engine. Back went into spasm (probably from twisting to get at heater controls), went home.
Belly needs to be cleaned. Need to look for “new” oil leak. Temporary breather tube needs to be shortened.
Product used.
Product used.
New 1/2 X 1/4 weatherstrip.
Heater now fully opening.
