My Airplane Projects
C120
Oil leak work, other.
Stopped at FBO and picked up oil test kit and ordered oil tank plug, O rings, crush gaskets, and Chemseal polysulfide sealer.
Adjusted voltage regulator down slightly. I noticed on last flight generator was pushing out 14+ volts.
Used Dremel and ScotchBrite wheels to clean old sealer off of engine bottom joint. Retorqued ¼” case half clamping bolts.
Flushed oil tank. Out came a dead housefly and a few other pieces of crud.
Test fitted the new snap studs and tried various screws and rivets for possible installation.
Former ooccupant of oil sump.
Old sealant coming off.
Fleet Model 16 Home
C120 Home
1356
Elevators
Exterior Finish
Flight Tests
311
Horizontal Stab.
Lighting
Preparation
Skiis
Wheels & Brakes
180
RV-12 Home
