Brief Description: Initial riveting on the rear spar of the HS
Normally rivets should go from front to back because of airflow. On the rear spar of the HS; though, the instructions say to put the rivets in from the bracket side. To keep everything on the same side, I did all the rivets from that side of the spar.
