OH BOY, was this super fun! As a rule, I hate applying stickers of any kind, but this was a total bummer. The only saving grace was the fact that you are directed to make a little potion of water and soak the tape and surface to allow for multiple movements and adjustments before the adhesive sets.
The trick was putting on the same length on each blade, and then equaling the section from the top and the bottom. Once that is done, your next never-ending task is simply chasing and removing a billion bubbles under the tape.
It wouldn’t be that bad, but then you realize that you still have one more blade to do before going to bed.
