Well, this was a total bummer. I went to install the alternator, but found it to be cracked. I called Safari, and they are sending a replacement right out. Thanks Delane! This is a drag, but I don’t blame Safari because this is not something I would think many companies would check or catch prior to shipping as part of a kit.
While trying to install the alternator arm before I found the crack in the alternator, I realized that the wrong size bolts were in the kit with the arm. It goes on the parts list with the alternator.
THEN I went to the starter. At least I could get this installed…oh wait…no nuts and no bolts. They are a specific thread for the engine, so I don’t have anything that will work. Again….on the list. I wasted a lot time, but this is all part of it, I suppose.
