Christopher's Web Site
Date:  3-20-2016
Number of Hours:  8.00
Brief Description:  Back in the World of Nut Plates…Oh Joy!
67 nut plates need to be installed on the engine shroud alone. I haven’t done this for a while, so I needed to get back in the rhythm of things, beginning with setting up enough drills so I wouldn’t have to keep changing bits. Here is the process:
Step #1 – Confirm and mark the location and side of the metal where you will be installing the nut plate.
Step #2 – Drill out the pilot hole to the size of the nut plate jig you are using.
Step #3 – Place the jig in the guide hole and orientate the jig so it’s aligned for proper plate placement and angle.
Step #4 – Use a strong spring clamp to help hold the jig from rotating.
Step #5 – Using a #40 drill bit, drill through the jig using a backing block to catch the bit.
Step #6 – Remove the spring clamp and reverse the jig.
Step #7 – Reapply the spring clamp and drill through the second hole.
Step #8 – Remove the jig and drill out the center hole to 1/4” to accommodate full movement of the floating nut.
Step #9 – Deburr all of the holes you just made.
Step #10 – Using a rivet squeezing tool and a countersink bit set, counter sink for flush rivets. (Make sure to countersink the correct side!)
Step #11 – Cleco one side of the nut plate in place.
Step #12 – Change out the countersink bit on the squeezer with rivet bits.
Step #13 – Measure for the correct length of rivet and install the first rivet in place.
Step #14 – Remove the cleco and install the second rivet.
Step #15 – Run a tap through the nut plate if you plan on being able to remove the screw several times during the installation.
Step #16 – Repeat 66 more times…..oh dear God….
Inside Shroud
Inside Shroud
