Christopher's Web Site
Date: 2-13-2016
Number of Hours: 1.75
Brief Description: Wiring Indicator Lights Complete
I purchased a Molex plug to use for the instrument panel indicator lights. I decided that I would like to make all of the connections to the panel removable in case I want to take out the instruments for service or inspection. I don’t think it's going to be a problem, but we will see. Everyday, wiring brings both questions and answers. Unfortunately, they don’t often equal each other.
As I mentioned before, I’m going to be dedicated with regards to labeling the wires. There are hundreds of them and it’s unlikely I will be able to remember where everything is going today, tomorrow, or 5 years from now.
Another question is if I am going to end up using these copper ground connectors that I made and installed on the breakers. I’ve heard some aircraft builders separating the grounds for the instruments, avionics, lights, and radios. If that’s my plan, I will need to modify these again. I’m still reading 12 volt books, watching videos, and talking to people, and the only thing that I’m positive of is that few builders do it all the same way. I have periods of confusion followed by moments of clarity. More on this soon….
Indicator Lights
Copper connections
Temp installation...
