Christopher's Web Site
Date:  3-15-2017
Brief Description:  Replace Ground Wheels
I mentioned before that my ground wheels didn’t have enough ground clearance to install and remove them without two people manhandling the aircraft. I tried to have them modified locally, but no one could find the diameter of steel needed, so Safari came to the rescue and made new wheel mounts for me. They are much better, but we will see how they will be on grass. It’s pretty close.
Of course installing these was a pain in the butt because I had to match existing holes, but mission accomplished.
Mounted on new frames
Drilled for installation to gear
