Christopher's Web Site
Date:  9-25-2016
Number of Hours:  2.50
Brief Description:  Carburetor Mixture Arm Modifications
Oh man was I pissed! There is NO way to install the carburetor mixture extension arm with the clearance provided on the exhaust system. I had to add spacers to make the notch even line up, but then I still needed more room to achieve the best angle for the mixture cable. To make a long story shorter, after flipping and grinding the lever in many different configurations, I was able to make it work, at least on the ground. It seems to work well, but I will feel what the action is like once the engine is running. What a pain in the butt!! This needs to be thought out and executed better at the shop before shipping!
Mixture arm modifications
