I am still tweaking the rods for the correct length and attachment, and I will be adding a sleeve spacer to the vertical throttle linkage to adjust its poor alignment, as you can see in the last photo. In addition, once the lengths are corrected, I will be using a joint paint to mark the position for movement.
