Christopher's Web Site
Date:  2-17-2016
Brief Description:  Heim Joints
As many of you know, the Heim joints that you need to install on the ends of the control rods are very stiff and have a tremendous amount of friction in them. The mitigation that needs to be done is to make a high speed drill attachment that will hold the bearing and fit inside a drill chuck. You then need to hold the threaded portion of the bearing housing in a vice or in some other secure manner while you spin up the bearing in the joint. As it heats up, the bearing moves rather freely, but after a short while, it begins to slow as the material expands. As soon as it starts to speed up again, I stop the drill and immediately submerge the bearing in water. The bearing will know move freely with minimal friction.
This process needs to be repeated a couple of dozen times to break in all of the control rods ends required for the ship.
The photos below show the efforts of the next entry.
Raw tubing
Raw tubing
Threaded
Threaded
Self-etching primer
Self-etching primer
