Gary's RV8 Construction Log
Date:  9-2-2010
Number of Hours:  0.00
Brief Description:  Z Brackets-Fitting & drilling to Left Fuel Tank 2
... continued ...
When everything seemed to check out using the old "Eyeball MkI", I took a 1/8" punch and gently passed it through a number the tank-to-spar attachment holes to double check the alignmen. The 1/8" punch passed neatly through the skin's holes and through the nutplates on the inside of the spar flange - close enough to use as an alignment check but no threat to the threads on the nutplates at all. Everything seemed to align perfectly.
(continued in next entry to accomodate more pics ...)
Bottom skin fitted to check alignment
Seam between fuel tank and leading edge. Is actually pefectly flush as per tank to main skin seam.
Fuel tank to upper main skin seam
