Brief Description: L-Elev Tip: Sanding front face to shape
I started VERY CAREFULLY using a bench top belt sander to sand the excess flox iff the L-Elev tip and get a rough shape for the front face. I then clecoed the L-Elev tip to its respective eleavtor and continued manually with a sanding block, sanding the tip face and sides to shape, using the counterbalance skin as a guide.
