Installed rudder Stops. they are made from a block of wood on each side. holes drilled and nut retainers installed with pop rivets into the wood. I then used Srcews as stops to make the rudder stop adjustable and embedded it into FLOX. I also drilled several holes in the wooden blocks to help the Flox attach at the interface points.
