Brief Description: Installed the Left Rudder Internal Bell Horn
I floxed all corners then laid 2 ply BID over and into flox corners. Then I added more FLOX in corners and 1 more layer of BID and Peel Ply. Once the 1st layer cured I temporarily installed the bell horn with screws and then drilled holes through the rudder Bell Horn attachment holes through the 1st layer and used FLOX to attach the Rudder Bell Horn. Once that cured I removed the screws and floxed the rest of the holes and laid 3 Plys BID after bedding the attachment in FLOX.
End of rudder capped and ready for internal bell horn
