Brief Description: Installed Relays and Started Wiring
Installed all 10 realys and started wiring. Ran Wires for Both Rear Canopy Prox Sensors using 22 AWG wire. I had to extend the wires for the PROX sensors about 4 feet so I twisted and soldered the wires then used Heat shrink over each junction then Heat shrink over the entire 3 wire bundle at the junction. I also ran both Wires for the Hyd Switching Valve using 18 AWG wire. I used crimps and then heat Shrink over the junction. I attached one of the Hyd Switching Valve wire to the Granding block. I also wired the Hyd Pump Solenoid positive terminal to the Positive terminal Block.
