BEZJet Build
Date:  12-18-2011
Number of Hours:  6.00
Brief Description:  Installed Hydraulic pump bracing, Relays and Paint
Faricated Hadraulic pump braces and glassed them in Place. Also, Installed Click Bond studs to mount the Hyd Pump relays. Cleaned eb=verything up and painted the inside of the nose. Then re-installed the Brakes, Hyd Pump and Relays
Hyd Pump and Relays Installed
Hyd Pump Bracing
Hyd Pump Bracing
Brakes Re-Installed
Brakes Re-Installed
