BEZJet Build
BEZJet
Nose
12-11-2011
Installed Hydralic Pump supports
Removed Nose Landing gear to gain access to Hyd Pump mount bolts and removed Hyd Pump after I had Hot glued the supports in place. I then laied 2 plys BID on each side of each support.
Hyd Pump Bracing installed and Painted
BEZJet Home
1426
Aileron
Antenna
Brakes
Cockpit
Firewall
Flight Controls
Fuel Sump
Intake
MLG
Motor Mount
Nose
Nose Landing Gear
Speed Brake
Strakes
Winglet
