Catch up Entry...I tried using Facebook as a log but that didn’t work out so great with Facebook blocking my Log Book account so I gave up on them and going back to KitLog. I spent a long-time sanding and Filling the Bottom of the Plane until it was smooth as glass. I talked to Nick Ugalini and used his technique to make sure all the waves were out of it. Basically, you pile on the Filler enough to ensure you don’t have to put more on and sand it all back off using long boards. Work pretty well. Once it was all sanded as smooth as a babies A$$ I applied raw resin to the whole thing and squeegeed it off. Then I taped everything up and primed it.
