Brief Description: Installed Hyd/Brake Lines and Bulkhead
I completed the Installation of the Right side hydraulics and brake line. Hyd Line is 1/4 in Al with Swage lock fittings. The Brake line is 3/16 Al with AN 3 fittings. I then was worried about leakage into the fuel tank so I created bulkheads sectioning off the lines and fittings. I will add a weep hole so that any leakage will be evident.
