Brief Description: Installed Hyd Bulk head fittings
I used a router to rout out a depression around the bulk head fittings. I then filled in the area with Flox around the fitting and covered the entire area with 2 ply BID and then placed a washer over the fitting and tightened up the nut. I peel plied everything. Once it cured I removed the peel ply and installed the Hyd Tubes. I debated whether I should section off the fittings in case of leakage into the fuel tank. I decided that it was unnecessary since I will complete a leak check prior to installing the top strake shell.
