Brief Description: Completed the Installation of the Carbon Hinges
I pushed FLOX through the Cleco holes and then used flox all around the hinge to get a smooth transition from the hinge to the structure. I then laid up 2 Plys BID at a 45deg angles to the hinge line on both the Rudder and the Winglet.
