Brief Description: Installed the Right Rudder return spring
I bored a 1" hole in the Winglet to install the Aluminum tube and rudder return spring. I then Embedded the tueb in Micro in the bored hole. Also, had to fabricate the Hook for the return spring and install it in the Tube End Cap
