BEZJet Build
BEZJet
Rudder Return Spring
Using a hole saw drill bit, I bored a 1" hole at WL25 to insert the 4.5" long Rudder Return Spring aluminum tube. Still need to make the End Cap. I have the piano wire and Return spring on order
Hole bored for 1" Tube
Tube inserted into hole
BEZJet Home
1426
Aileron
Antenna
Brakes
Cockpit
Firewall
Flight Controls
Fuel Sump
Intake
MLG
Motor Mount
Nose
Nose Landing Gear
Speed Brake
Strakes
Winglet
