Brief Description: Completed and Attached the Rudder
I completed the Inside channel layup and trimmed the layup. I then Laid out the hinge pattern and drilled and fastened the Hinges. As I worked through the placement and alignment of the Hinges, I started at the Top placing the top Hinge and then the bottom Hinge. Then came back and placed the middle hinge. Once everything was in place, drilled and fitted, I attached Nut plates to the hinges and attached the Rudder.
